[Pro] RE: No Freeway settings in Mals
Hi,
I have no Freeway settings in my mals cart? what does this mean if I do not have it? I have taken a screen shot but do not know how to paste it here for you to see.
Andrina
actionsdev mailing list
Do you mean that there is no malsettings.cfg file in your site folder on your Mac?
It is created by the action within FW and uploaded to your server with all the other FW generated files such as your .html files
Are you using FW to upload your site?
Hi,
I did the cyberduck as per tim’s instructions (thank you) and found the file mals settings.cfg and got this URL:
ftp://email@hidden/malsettings.cfg
I entered it into mal’s and freeway and hit upload, still to no avail.I still get the message 404 from mals
GO DADDY suggested:
I have to point to my cart. And this is where I do it:
To Add a Subdomain
Add DNS Record window displays
Host Name — Enter the subdomain you want to use.
Points to IP Address — Enter the IP address you want the subdomain to point to.
What do I put as a Host name and what is the IP address?
Also as per my other message, I do not have a freeway settings in Mals E under cart setup?
Please help!
Andrina
yes I am using freeway 5 pro.
Andrina
got this URL: ftp://email@hidden/malsettings.cfg
That isn’t an URL
The URL is http://www.yourwebsite.com/malsettings.cfg and if you put the correct URL in the address bar in your browser you should see something like
bgcolor_color=#000000
cart_width=600
cart_align=Left
font=Verdana
font_size=2
bground=
text_color=#000000
link_color=#0000FF
vlink_color=#800080
alink_color=#FF0000
table_color1=#C0C0C0
table_color2=#808080
table_text1_color=#000000
table_text2_color=#FFFFFF
Once you have it correct then put that info into Mals - you may not need the malsettings.cfg on the end.
when I look in my site folder in freeway I can only see the pages I have made no malsettings.cfg page, should there be one? is this what you mean?
Andrina
I do not have a freeway settings in Mals E under cart setup? Please help!
Do you mean that you have not entered the Website URL in the ‘Your Details’ section in Mals?
When I go to this with my website name added, I see a message saying: ever feel like you’re in the wrong place
Error 404 page not found
Andrina
Yes - that file should be in your Site Folder (on your Mac)
Have you applied the E-Shop Settings action to your Site Folder?
Yes I have entered into mals your details, many different URL options to try and get it to work, then when I click on an item to buy on my site it says…see below
Andrina
FREEWAY CONFIG
The shopping cart will automatically attempt to load a new configuration file when you change your settings in Freeway.
Sorry, it was not possible to load your new configuration: It was not possible to connect to your webserver at:
http://email@hidden/malsettings.c
Please login to Admin and correct the URL in Your details
Yes I have pressed on site folder and filled in details under E shop settings and put in my user ID and key code from mals etc…
Andrina
What is your website address?
herbs2healme.com
So does your site folder in FW look like this - with the action icon on it?
I only have Buy buttons live on the shop - herbal tea page so far.
yes site folder has the orange action pic on it, and so does home and shop herbal tea.
Not important - does the Site Folder have the action icon on it?
yes
OK
Try holding down the Ctrl Key while choosing File>Publish Everything
Once you have done that look in the Site Folder on your Mac and see if the malsettings.cfg file is there now.
OK Done, no malsettings.cfg folder appeared.
