Sorry first post & I’m not at all techy.
I’m making my new site using FW7, infow with Backdraft as my main input blocks. (Love Backdraft, hair saver!)
My web site is 100% black background with mostly white text style and lots of images. (using 2 wrapper alt for most content if it matters)
When I preview my pages, the more is a plain white block. I suspect (but don’t really know) that it probably is all working except for changing the background of the more block to black or the default page background.
I need some very, very basic teach your grandmother instruction how to do it! Assume she knows nothing but loves you!
Thanks so much Barry
within twoWrapper, there are (two) items called twoLeft and twoRight. Once selected you should recognize in inspector that they both have a background of white applied. Chances are good to change this to none (transparent or whatever the correct translation might be.
But it might be as well that I’m entirely incorrect here.
Thanks so much Thomas and Delta
Thomas, the black background is all good re: twoWrapper etc, it is just the plain white box that appears after the “more” is clicked.
Delta- yes just the background of the box (assuming but I can’t tell yet) that the text is there properly.
I am very reluctant to start messing in areas that I’m ignorant of as FW7 only has 1 undo.
I copied the text you suggested and found my way into the page/html but didn’t know how to proceed with “Markup in the before end </head”
Can you guide me a bit further
Thanks Barry
And if you save your work before you do anything risky (not that this is as you can just delete it if its not what you want) you can just close the file without saving and reopen to get back to where you were.
