Hi,
I’m trying to set up the read more action…
I’ve inserted text into a html box then at the end of the paragraph inserted the action then continued with some fake text, but the text after the after the action is shown and when you click on the more it just shows an empty box…
Please help I know i’m just doing something slightly wrong(well i hope)…
First paragraph of text goes here and here
and here and here and here [Read More]
Second and further text goes here and here
and here and here
Make certain that the inline ReadMore Action is the last “character” of text in the first paragraph. It should be inline within the text, and it should not be separated from the paragraph that contains it (not on a separate line, for example).
On Jun 4, 2014, at 1:44 PM, colin hart wrote:
Hi,
Thanks for your quick response, if you check the link example now i’ve wrote the first paragraph then added the action as the last character the pressed return to start a new paragraph but now the box doesn’t appear?
Sorry to be a pain…
You need to use a newer version of Prototype, and then it will work. I have an Action in the Forge called PrototypeUpdate PrototypeUpdate - ActionsForge which will help with this problem.
On Jun 4, 2014, at 2:20 PM, colin hart wrote:
Hi waltd,
Sorry to be a pain…
I’m so sorry to be a pain but i’ve uploaded your prototype update, shut down freeway and started again but it still doesn’t work…
I’m using freeway pro 5.4.1 version if that helps?
It shouldn’t make a difference. You applied the PrototypeUpdate Action to the page, correct? I don’t see any evidence that you have done this. The version of Freeway shouldn’t make any differences.
On Jun 4, 2014, at 3:25 PM, colin hart wrote:
Hi Walter,
