Hi -
I need a home page to know its being read by IE all versions so I can have two home pages one for when IE reads it and one for the rest of the browsers?
Is there a bit of code to do this and how can I add a bit of code in Freeway Pro?
Cheers!
Not quite sure what you are asking here.
Is there a feature on your home page that IE does not support and other browsers do?
Or do you want to create a page purely for IE visitors like “Bog off and get a decent Browser!”
Yes Im using PNG’s that render horrendously in IE so would like a redirect to a page that will not be using PNGs
Remember that you can use conditional statements to change items on a page to support this but if you want to redirect all IE users to a different page then use something like this
<head>
<!--[if IE]>
<meta http-equiv="refresh" content="2;url=http://www.google.com/">
<![endif]-->
</head>
But only older versions of IE have a problem with pngs so you might want to use
<head>
<!--[if gt IE 7]>
<![endif]-->
</head>
Excellent thanks
J
Sorry - that shoiuld of course be
<head>
<!--[if lt IE 8]>
<![endif]-->
</head>
In other words if IE is less than version 8 then redirect
I am not exactly sure at which version IE started using pngs properly?
Im on 8 now and they look terrible, so will be using which If IE
Im using IE 8 and it looks terrible - so will use - if IE
Sorry repeated myself
Post a link so that we can have a look because png support was supposedly introduced in IE7
Maybe something else is your issue.
k - take a look
http://www.easthalldesign.com/car/
oh its the CSS transparency rollover thats making them look so bad - thats ok Ill remove that for IE only
You do know that IE8 is not CSS3 savvy but 9 should be and Microsoft certainly have a big Advertising campain here promoting 9
