I have a form that users can fill-in and send to us. I’ve added an extra field near the top on the list of fields, but in the email sent back to us, it’s the last field. How do I change the order?
Turn on the View / Tab Order option in Freeway. To change the order of
the individual elements, you can click on the Site header above the
site pane (left side of the screen) and change it over to Page view.
You will see a hierarchical list of page elements, and whenever you
click on an element in the design side of the screen, the
corresponding item in the list will be highlighted.
Dragging elements higher in the list moves them backward in Z-space
(toward the page itself, which is represented by the page name at the
top of the list) and moving them down the list brings them forward.
The form elements are listed in the source code starting with the
highest element on the list and moving toward the bottom of the list,
so simple drag and drop should get them into your preferred order. You
will see the tab order numbers change as you re-sort the elements.
On Jan 25, 2011, at 8:32 AM, Kevin Cheesman wrote:
Hi,
