Hello, I have a question for you. How do I create form with required fields?
The site that I created (http://www.holiddays.it) I used jotform, you can see the sheets onthe sub es apartments: inside, outside, etc., but I want to create the shape without using …jotform, you can create similar form on the freeway, I do not understand how I read thereference manual Freeway and also knowledge base.
I understand if the use of PHP feedback form, do not need reCaptcha to block spam.
I want to use freeways and do not rely upon external third-party solutions, I think it ispossible to do this.
I’am Italian and use google translate, my english is dirty
If you use PHP Feedback Form, you get only a little bit of validation:
if you create a field named ‘email’ (just like that, lower-case
letters) then the user will need to enter a string of text that
appears to be an e-mail address. Other than that, you will need to use
the Validate Form Suite Action, available at http://actionsforge.com.
Note that this Action uses JavaScript to check the form fields, which
means that you cannot trust it for anything important. All that a
malicious user needs to do in order to submit anything is to turn off
JavaScript in her browser.
There are other solutions, but none as well integrated with the
“Freeway Way” of building pages.
fields?
to block spam.
