[Pro] resizing iFrame
Hello Dave. Thanks a lot.
Just a question, please.
When you said “And the iframe is called using…” Does it mean that you dont use the iframe action?, or that the iframe action writes this code for you? In first case, you insert this code before , isnt it?
Thanks again
The first script goes in the Head of the page ie After and before end - I prefer before end
And no - you don’t use the iFrame action because it is not so easy to add the onLoad event to it.
In mine I used Insert>Markup Item
ok. Thanks!!
