For some reason, I am suddenly not able to resize Quicktime Movies imported into Freeway.
Can anyone help?
Jon
Can anyone help?
Jon
Are you using the Item>Actions>QuickTime Extras?
What version of FW
I have tried, but with the same result. I am using FW 5 Pro. I was not having this problem previously…
Maybe I changed something?
Remember that if you use this action then your movie container HTML box should be resized to your desired output size and the relevant Movie Scale selector be chosen ie Aspect
Why are some actions not listed at actionsforge.com? I occasionally see
references on the list to actions that I can’t find there, and I have kept
the old actions link so I can look there. The QuickTime Extras action is
one of those. I did find it at the old Softpress link, but why isn’t
everything listed at actionsforge? Just wondering.
Robin Stark
All of the built-in Actions are excluded from ActionsForge by Softpress so as to avoid confusion and maybe double-installation. Maybe it would be a good idea to add them and keep the version info current, but not provide a download link to the Action file.
It’s a built-in action? I don’t see it. Oh, oops. I have to have
the QuickTime movie in their first. Got it. Lord, why are some of the most
obvious things so hard to figure out?
I think that’s a good idea to add the actions to ActionsForge and just make
a note that they are built in. I like looking through ActionsForge to see
what’s there, and if it really included EVERY action, I wouldn’t be wasting
everyone’s time on this list asking STUPID QUESTIONS!
(Just kidding, I would still be doing that).
Robin Stark
download link to the Action file.Walter
