Erik
(Erik)
June 5, 2013, 1:12pm
#1
Hi Guys,
Need some help
Try to make my site responsive,
Now I’m trying to integrate a WOW slider but something goes wrong. Slider works ok local, but after uploading it breaks apart, does this have something to do with settings for responsive maybe?
blanco test page:
http://www.graphicid.nl/slider.html
thx
Erik
No - cause you have no “settings” for responsive on your current slider example.
All you have are broken links (404) for the images. Adjust them first.
Erik
(Erik)
June 5, 2013, 4:29pm
#3
Hi Thomas,
No idea what you are trying to say?
Where can I do these settings?
I thought that the WOW slider was responsive itself
When I test local the slider is responsive
Hi Erik,
you have either to adjust the paths for the images in the source-code of the slider-script or load them onto your server.
The next point is, that you wrapped the WOW slider-code within an absolute positioned item1. This can’t work in the sense of responsiveness. Only a relative positioned item with a width of 100% can work here.
Erik
(Erik)
June 6, 2013, 12:54pm
#5
Hi Thomas,
The data and Engine folders which WOW slider generates ARE on my server (within data folder are the pictures)
After that
I generate an new blanco page and the only thing I did was insert MarkUp element and paste the code.
Do you mean that I have to give the Markup element different settings for responsiveness?
Erik
Honestly I’m not sure cause I never gave WOW a real and concentrate go. I use totally different stuff.
But (I guess) you use Calebs’ template?
So if yes - out of mind - he wrote a “How to” regarding WOW sliders and their integrating.
So maybe giving him a quick call?
Erik
(Erik)
June 6, 2013, 1:32pm
#7
Yep using Caleb’s Backdraft!
try to contact him,
Thx for your feedback Thomas!
