[Pro] Responsive CSS Menu
Is it possible to set an on state manually when creating a menu using Responsive CSS Menu Action?
Matt.
Not at this time. You may want to post that as a feature request here: Responsive CSS Menu - ActionsForge
Also, if you want to add this yourself sooner, here’s a simple JavaScript recipe I often use when making self-links “light up” like this. Paste the following into Protaculous 2, and adjust the nameOfTheBox reference to match the Name/ID of the HTML box containing your menu.
var here = $$('#nameOfTheBox a').sortBy(function(elm){ return elm.href.length; }).reverse().find(function(elm){
  var link = elm.readAttribute('href');
  return (window.location.pathname.include(link));
if(here){
  here.addClassName('active');
Then you just need to add a new CSS style to your page with the Tag set to .responsive-menu > li a and the Name set toactive. Any background-color property you set in this field should override the Action-defined default background-color, and you will get the effect you’re after.
Matt.
Thank you for getting back Walt, not sure if I used the correct term ‘on state’.
what I am after is the current page to be highlighted.
In css menus you could select ‘highlight current page’ and then you check ‘Current page’.
when you go to http://rachelcrispcounselling.co.uk/fwp/ I would like the current page to have the hover state.
Matt.
That was the question I was answering. The Responsive CSS Menu Action does not currently have this feature. The code that I posted will give you that effect until such time as it does have that feature. Did you try that yet?
Matt.
oops! yes have updated link but still don’t seem to be able to get to work.
Matt
Okay, two things. First, put the script in the DOM Loaded Observer editor, not the custom script. I should have mentioned that earlier. Also, apply this to each page in your demo site, so you can see it work on each page.
The way that the script works is it parses the URL on each link in the navigation, sorts them into longest-first order, then tries to find the first match in that array of URLs to the current page’s URL. It works longest-first because otherwise most pages would match the home page. It’s probably not going to light up on the home page unless you are actually at /index.html rather than / in your browser.
Matt
Hi al… I am also interested in this option, so Ill throw my hat in
Carla
Walter I still can not get it to work would this CSS below be correct?
.responsive-menu > li a:active {
background-color: #8CADA2;
Matt
Use a dot between a and active, not a colon. The script adds a classname to the link, :active is a pseudo-class, and only the browser can add those. As far as I know, there isn’t an :active pseudo-class to add.
Matt
Hi Walter, That works a treat!
Many thanks Matt.
Hey Walter,
I’m using the new Freeway 7 and I am setting up a new menu. I noticed the responsive hamburger size is set pretty small. Can I increase the size somehow?
Billy
The new action allows you to choose your own image for this.
I have an image 179x69px. When I publish the page and look at the image it is very tiny. Not the size i’m expecting.
Billy
You can see it here.
http://smartytest.com/Greek/ourwork.html
You can get round the fixed size by adding the following to the Page>HTML Markup dialog (in the Before section):
.fwNav1-toggle-label { width: 90px; height: 40px; }
Cheers,
Thanks Joe.
Also how do I exclude my CSS Styles page out of the Menu Auto Generate?
Billy
Sorry, I’m not sure I follow. Are you asking about externalizing your CSS styles? you can do this in the Output tab of the Document Setup dialog (Command-Option-,)
On 1 Aug 2014, at 14:11, billy kimmel email@hidden wrote:
Thanks Joe.
Billy
No. The new Auto Generate in the CSS Menu. It is picking up my CSS Style Sheet(page) in my folder of my site. Should my Style Sheet be in a separate folder?
Also, what is the class of the hamburger “close” button? And is there a list of classes for items in freeway such as .fwNAv1-togle-label?
Billy
Ah, I see. There’s a Remove from CSS Menus Action that you can apply to any page you don’t want to include.
There’s no published list. The easiest way to find things like that out is to open the page in the browser, right-click on the element you want to find the details of and select Inspect Element. If you use Safari you may need to turn on the Developer Menu in the Advanced preferences to do this. Firefox and Chrome both do it out of the box.
That particular element has a class of .fwNav1-toggle-close
Billy
