[Pro] Responsive? or users can zoom with 2 fingers!
Hi and good day,
I was trying to turn our old in-box site into a Responsive site when I started to wonder if this is worth it. I mean smartphone users can zoom with 2 fingers just a little and then I think the site is quite readable (tell me if I’m wrong).
Yes I know the Google ranking is worse for non-responsive sites.
But it’s not as easy as shown on the Softpress video, esp. when a site is built with box-model. Mainly the float-Right boxes have to placed under the float-Left boxes, which if above my notch.
Probably better to start from the beginning somehow differently, but then the box-model structure would be lost, which is bad enough.
I would be glad to get some hints/ ideas in this respect.
with best regards,
Omar K Neusser
Stockholm, Sweden
(skarholmensmoske.se = we have a mosque and we are against extremism & terrorism, no matter from which side.)
http://www.skarholmensmoske.se/
No it isnt that easy but the best results come when you do use an inline (box model) construction.
Working inline ensures that you get a ‘natural’ resizing/repositioning effect.
Start small and build a Master that works then take it from there - you dont have to do it all at once. Do it in a sub folder of your existing doc then you can easily copy and paste.
… or review my screencasts (and your strategy).
You paid it for successful and quick building of theGrid.
”… or review my screencasts (and your strategy).”
Yes Thomas, this will be my only strategy, to build the site from scratch.
(Oh this is a daunting task, I had hoped to keep the site for the DEFAULT size and just to rearrange the divs! for the SMARTPHONE size.)
And I’ll follow your excellent tutorials (like ’gridmeister’ etc.) step-by-step.
with best regards,
Omar K N
Stockholm, Sweden
