Hi Ben,
Upload the page to your web server and the ‘JavaScript’ will change to your site domain. The browser shows you ‘JavaScript’ because there is no domain info when you run the page locally.
On 13 Nov 2012, at 11:32, Ben wrote:
When I apply the script my pop-up says:
“JavaScript”, followed by my added copyright info.
How can I change the text “javascript” into the http:// ?
Found the solution. In the mark-up pane I have two times a “before and after head” the first one comes after the “HTML-section”. The second one just below that before the “BODY-section”
If I use the second one (“After Head”, just before the “Before Body”) everything works ok and the text “javascript” has changed in to my “http-adress”.
The sript also works for the galleries generated with showcase
Thanks a lot for the script.
Now hopefully there will be an update from exhibeo to incorporate exif data (as you can still download the images)
Thanks for your response (I just was typing my update).
The strange thing was that also after upload I had the same “problem”. Changing it as I described in my previous post solved it.
I am an absolute novice in this field, so I don’t know if this has anything to do with it, but anyway it works.
