[Pro] Rollover and Carousel Button
Hi all,
Is there a conflict with using a rollover as a carousel button? I can’t get it to work. I’m using the newest versions of the Carousel, Carousel Button and Carousel Tabs actions. I found some discussion about this in an older thread (http://www.freewaytalk.net/thread/view/49499#m_49506) but I think it was associated with the old version of Carousel.
Warner
I know I fixed the problem with the Carousel Tab, but I may not have done for the Carousel Button. If you haven’t yet, try changing the order that you apply the Actions, and see if that helps. Carousel first, Rollover second, and vice-versa.
Yeah, I did try that Walter. No good. I even re-did everything a couple of times and tried re-downloading the actions just to be sure.
Warner
