Hi,
I have graphic buttons but would like type to appear when the person rollover the graphic. how would i go about it?
Peter
Hi,
Peter
Target show/hide layer action
Standard action for pro
Apply rollover to your graphic
Apply target s/h to an html layer containing your text (and or images)
Set parameters in action palette to match
Done
thanks David will give it a try.
Peter
Hi David,
Have tried what you suggested, but have a problem.
I have two graphics boxes which are aligned one on top of each other and one is acting as a rollover. When someone’s mouse goes over the top i want the text to appear below it
When I try to add target s/h layer to the graphic boxes the action doesn’t appear in the actions box.
any ideas?
Peter
Peter can you post a link to what you have so far.
Quick example here
http://www.deltadzine.net/test/rolltest.html
will do Dave thanks.
Peter
