Hi - I’m fairly new to Freeway and want to make a roll over where if I roll over a graphic item another graphic item appears in a different location on the page.
The idea is to have a menu and when rolled over just below the menu some information appears.
I cannot seem to do this, is it possible?
Also is there an easy way to make certain sections of text a HEADER1 without messing with the styles etc which seem to cause me headaches!?! I’d also like like to add Author information in the code is this possible?
You can add the Author info, into the META data of the page. Under the page menu, select META Tags, then click new, and add “AUTHOR” and then the value…as for your first question, about rollovers, I think you want to be looking into the “Target, Show/Hide Image” actions.
Or Target Show/Hide Layer
You can also edit the H1 styles in FW so that they are more in keeping with your other text styles.
Click the ‘Cog’ in the top of the text style inspector window>Edit styles
Click on the style you want to alter in the list of styles on the left and then you can change things on the right. Remember to click OK (bottom right) once you have finished.
