[Pro] rollover oddity
i am having trouble with a simple rollover. it is made of two 100x25px images; one has a white background, the other blue. their size is 4k each.
well, after going through the process of creating the rollover (which i checked and re-checked) it previews normally in FW but when previewed in a browser or uploaded to the server something odd happens: the rollover works but the mouseover image is reduced to a 10th of its size! it becones a speck of blue over the white normal state of the button.
i just do not get this: they have exactly the size. any ideas as to why this is happening?
Post a link Edson please
ok. actually, there is more than one odd thing happening.
at http://www.mahfuz.arq.br/test_site/escritorio.html, there should appear a button between “portfolio” and “equipe”: the normal state is not showing.
at http://www.mahfuz.arq.br/test_site/portfolio.html there should appear a menu bar to the right of “portfolio”. the normal state does not show and the mouseover state appears as a blue speck on the top left hand corner.
on the other hand, on the english side of things, all the rollovers work fine. http://www.mahfuz.arq.br/test_site/office.html. go figure that.
thanks for any help.
