Can someone guide me how to create rollover text linking to within or outside of site. I can’t find an answer. I am trying to create text links - when the mouse moves over to the link text it will change color.
Example, the link text is “blue” and mouse over text then becomes “red.”
3 - Select Link 1 Text and Apple+K (Edit>Hyperlink) and in the dialogue box that opens you have options Internal and External. If you want to link to a page in the site you are working on then select its name from the Internal list. If you want to link to a page on another site then click External for more options. Choose from the Protocol selector - if you are linking to a web page somewhere else choose http: and then type in the rest of the web address of the page you want to link to ie www.somebodyelsessite.com/index.html
If the link is for an email link then add in the email address after mailto ie. jimmy(at)me.com
4 - Once the links have been created then select the HTML box with the links in it and go to the Inspector HTML item and click on the Paintbrush icon.
You will see a disclosure triangle next to Links, click the triangle to show the options and choose your colours for the various states. Note that to the right of the colour selectors there is an underlined U repeated clicking on this will determine whether your links will be underlined or not. Normal state is underlined, 1 click underline off.
Two ways to do this: page wide and specific settings for a text area. Page wide settings are done via the “Links” section of the page appearance settings in inspector.
Separate text area settings can be applied using the “Text Link Style” item action.
