If you look at the “Contact” page. The rollover text is yellow. I want that to be the same on the “Home” How do I get this to work?
www.advancedmediaproductionsllc.com
Howard,
here as well (cause of actuality) a question first:
Who advised you to use tables as preferred layout method?
Point 2:
Even a two link containing navigation could be built by using the css menu action:
http://www.kimmich-digitalmedia.com/articles/css-menu-challenge
Point 3:
Using “text links” requires a solid style strategy. Remove all style properties from the current links. Then either select NOTHING or the item you want the link styles apply to and head to inspectors pen tab bottom and find the links dialogue. Adjust the
NOTHING selected:
The link styles work page-wide (all links on your page behave the same)
An ITEM selected:
The link styles only work for this particular item.
That’s really really weird, but I didn’t originally have it set as a table. I had it just text. I’ll try changing it and see what happens
I meant that I just used one of the templates that Freeway came with as my client liked that feel for it
I am just really confused on why on one page it works, and another it doesnt
Honestly not to examine (for me) from the source code - sorry.
Maybe a look into the FW file could clarify this.
Yeah, that’s what im in process of doing
