[Pro] rollover thumbnails
I found rolling over thumbnail images and bringing up an enlargement quite straightforward in freeway express. Tried the exact same procedure in PRO and it fails to work! Anyone help? Example is here: http://www.simonfrancis.org.uk/PhotoImages/betweenyouandame.html
Simon
You have to remember that Pro uses layers - your images are appearing but some appear behind others.
Thank you David. I will trawl through the manual regarding layers.
S
