[Pro] Rollover with Multiple Targets
I am trying to achieve a specific effect using the Rollover feature, and am having some trouble figuring out if this is even possible with Freeway.
I realize that if I use Rollover, I can assign multiple images to the same Target number, in order for a single Trigger to change multiple images simultaneously.
However, what I would like to do is a little more specific:
I have 5 buttons down the side of the page.
When I click Button 1, I need Target #1 and Target #2 to change.
When I click Button 2, I need Target #1 and Target #3 to change.
When I click Button 3, I need Target #1 and Target #4 to change.
Basically, I need #1 to always change with each button, and I need a completely separate Target to also change.
I realize I can reproduce Target #1 many times - but it seems to me that this would complicate things/create excessive load-time and overly complicate the design process? Or would it not affect page load times because in each instance it would reference the same .GIF file? Just seems like a PITA to have to recreate the same image and manage all their layer positions for each button…
I figured out how to do this!
I downloaded the Rollover 60 Action from ActionsForge, and now use BOTH Rollover and Rollover 60 simultaneously to Rollover 2 separate images.
It would have been nice if Freeway allowed me to add the Rollover Action twice, but luckily the Rollover 60 action seems to be identical to it, thus allowing me to have 2 instances of the Rollover action functioning on a single Image link.
