Hi,
I’m working on a rollover effect. On the bottom of the page i have 4 boxes (images, red border/white inside) that represent 4 pages. I’m trying to create the effect that when you rollover a box it turns entirely red and the title of the page appears above the box. (see screenshot: http://temp.shizihou.nl/rollover.png)
This is easily done with the rollover effect. But the four squares are close together and the text of all four squares should appear at the same place. But when you create the rollover effect it effects the entire area and now it overlapses it doesnt work. I want the effect only when you rollover the box and not the area where the text would appear.
I think it is possible. If you apply the Rollover action to the red boxes as usual and also have the words in separate html (layered) boxes, over the top of each other and apply the Target Show/Hide Layer action to each of them, each with a different Target # corresponding to each rollover box. You should get what you’re after.
Hi sly,
thanx for your reply. I understand the priciple, but i can;t get it to work. Could you give me a more step-by-step explanation? Very much appreciated!
