[Pro] ROLLOVER
I am trying a rollover using two graphic items. I have imported images into each.
I want one of the boxes to show on MouseOver.
No matter what I do, when I preview, that box is gray.
When I MouseOver the image appears. But I remove the cursor and the box turns gray again.
I know the answer has to be simple…
Hi Kieran, how are you. Check that the colour of that box has no background colour, that the colour = None.
As a test, I can create a red box on top of a green box and create a perfect rollover.
When I use two graphic boxes with imported pictures in them nothing works.
I clicked off layered in each item. One box sis on top of the other, but when I go to the Insert-Actions Menu I get Text Rollover, not regular rollover.
Neither box has a color background.
Hi I am a bit lost because I am creating rollovers and trying to make a mistake that seems to replicate your problem but am unable to replicate what you are experiencing. I think it is better that someone with more experience offers you some advice here.
I just can not understand how you can create the red and green rollover and not the image rollover. Maybe you could try inserting the images via the “Actions palette” itself in the “parameters” dialogue as opposed to importing them through command + e (insert+import)?
Kind Regards
Chris
If you simply want 2 images to work as a rollover ie cat picture rolls to dog then the procedure is this.
Draw graphic box and import cat picture. Size cat to suit.
Apply rollover action.
In the action palette change from Images to Parameters view
In the MouseOver pulldown choose Select - then navigate to the picture of your dog.
Note that the picture you choose for the MouseOver state will be resized to fit your graphic box - so best to choose an image that is already sized to fit.
Done!
