[Pro] RSS Feed and Umlaut
Hi all,
my first post here, so hope I can describe you correctly about my problem.
Its all in all the same: Called Umlaut (ä, ö, ü). By trying out the RSS Feed action I realized, that by adding the Feed, it appears with funny signs in the browser. By adding a search feature, all the page titles (from the inspector) appear with those funny signs. By using forms to go, it show me the little buck, when I´m dealing somewhere with Umlaut. The problem is, that I cant sort out, where I should search or not. I tried to change the code from “automatic” to UTF-8 with no further success. In the RSS action I tried to replace the Umlaut throughtheir html-expression (ä) and even in that forum it`s impossible to deal with it. What would suppose?
Thanks for your replies
the site if you wan`t to doublecheck http://www.meteon.de/new/index.php
ok
… the RSS feed seems to disappear into thin air … without any explanation to me (rechanging from the html ü-version to the ü then uploaded and now I see the Umlauts. But anyway - Umlauts are the most common problems.
Best regards
