I haven’t used the current iteration of the RSS Feed Action, but I wrote one years ago called SimpleRSS. The way that one works is you create an HTML box on your Freeway page, populate it with a structured set of data:
Headline with link to the full story
Description to appear below the headline.
[repeat]
As long as you a) don’t style this text at all using inline styles, and b) always have equal pairs of a linked “headline” paragraph (line of text concluding in a full Return) followed by a description paragraph, then applying the Action to this donor HTML box will create a nice RSS feed for you and link it to the page with an auto-discovery link tag. You can either leave the HTML box visible in your page (and use external CSS styles to make its content look the way you want) or the Action will remove it from the page (so you could leave it on the pasteboard, and update it whenever you need to change your feed, independent from the visible content on your page. My understanding of the new RSS Feed Action is that it does some similar text-munging based on a page element.
So that’s one way to build this. Another is to use a blogging software of some stripe, and that has other benefits. For one thing, usually you can update the content of a blog using a browser from anywhere in the world. Unless your client is using a Mac and owns Freeway, the former technique will be a non-starter.
Once you have a feed established somewhere, it’s trivial to add the auto-discovery link to your pages: open the Page / HTML Markup dialog, choose a slot inside the HEAD (either After HEAD or Before /HEAD) and paste in the following:
<link rel="alternate" type="application/rss+xml" title="Your Site Name" href="http://example.com/rss.xml">
If you do this on a Master Page, you will get the link everywhere in your site. Naturally update the link to point to YOUR feed file. If you’re using one of the Actions or a blog application to build this, you will get the same result.
On May 10, 2012, at 8:14 AM, Jonathan Riddle wrote:
Hi all,
I have had a request by a client to introduce an RSS feed to their website, but I don’t know anything about it.
I know Freeway has RSS actions, but where does the feed come from? My client will want to update the information themselves, with the feed containing information about their company and ongoing projects, so will that involve them signing up for a blog-like service to generate the feed which the Freeway RSS actions then link to?
Also, can I link into other RSS feeds which would be based around the sites subject matter?
Thanks in advance
Jonathan
