If you need the effects of Sctiptaculous, then yes. If all you need is
prototype, then you can choose prototype-packed.
A word about the “un-packed” versions: these are there for when you
are debugging your code. The packed versions have had all of their
function and variable names replaced with individual letters, and the
whole thing mashed down to three or four lines of text. It’s murder to
figure out what’s wrong when the error message says the problem is on
line 1!
Once you have everything working nicely, switching to the packed
versions saves you about two-thirds the total file size.
On Oct 4, 2010, at 12:24 PM, kitesurfer3 wrote:
Thanks, so I should always use “Scriptaculous-packed”
