Hello, I’m using Freeway Pro 5.5. I’ve set up a slide show on the home page which disappeared when I previewed it in Safari. I’m using a green background with a white graphic block on it the same size as the page, so there’s a green band at the top with the website title. I got the slide show to reappear when I clicked on the white block and chose ‘Send backwards’ from the ‘Item’ menu. It’s working fine now, but when I try the same procedure on another page, with new images, I can’t see the slide show, only the white graphic block. I’ve tried ‘Send backwards’, but to no avail. All the other settings/actions on both pages seem identical to me. Would anyone have any idea what the problem might be? I’m sure it’s a minor thing, but I don’t know what. I’m using a CSS menu set up at the top of the page. Any advice greatly appreciated!
Gerry
