Hi guys. I’d like to have a small slideshow play over top of a jpeg header. I could use Flash to make the slideshow but I want to avoid the Flash problem on the iPhone/iPad. I know the customer will be viewing the web site on his iPad. I’ve tried it several times & I keep getting the same result. Not only does it not play but graphic box underneath it winks on & off with it. Hopefully someone can help. Here’s the link.
Thanks David for the response. If I uncheck Combine Graphics in the Inspector, the Target Show/Hide Layer action becomes unavailable. So what I did was remove the graphic that was underneath the slideshow, built the slideshow & put the graphic back underneath. It seems to have worked. Thanks for your help.
