Oh and one more glitch…
I would like the scripty accordian inside the CSS menu to mimic the color states of the other CSS items on menu
but it does not. I did specify in the Inspector Link but it does not obey.
thanks for any advice
Sorry Carla no idea - have you tried selecting the page title in the LH site pane and copying from there into your other doc. You know you can always email me the page.
Yes first I tried that that did not work
Then just made a new page and copied the CSS menu
Menu works but accordion does not appear
What is your email again? Thanks for helping
C
Hi Carla - yes I got your HTML page but it is quite difficult to work out what is going on as images are referenced elsewhere.
If I understand what you are trying to do it is to create the same hover/link styles as in the CSS menu - just not sure if it is doable without a fair bit of hand coding.
I will have another look later but it would help if I had the FW page itself. Select the page name in the site panel Edit>Copy then open a new FW doc and paste it in. Give the new doc a name and Save Archive. Once you have the archive file zip it up and send it.
Dave
I did what you asked but as in trying to save this page/menu on my other site. It simply will not copy all of the script accordian info
I will send the file to you though… Maybe you can see it underneath.
