i can’t get scripty accordion to work on a page (see link).
first i’ve used preview mode and the action did its work well, after uploading it stopped working and all text were visible.
(inline layout, fw pro 6)
any ideas?
dieter
That’s what I see, too. Locate your Site Folder (on your Mac) and delete everything within it. Publish your site again, and upload. This looks like a glitch with Action-published files.
On Feb 27, 2013, at 8:30 AM, Thomas Kimmich wrote:
I’m under the impression that scripty needs prototype and scriptaculous to work, but that both libraries are missing for whatever reason.
thanks thomas and walter,
i’ve deleted and uploaded again - no success. the only file new to me is “html5shiv.js”
which file should be there?
dieter
They should be pointed to prototype.js and scriptaculous.js, respectively. Can you check that you have the very latest version of SA installed? Check on ActionsForge, and compare with the version number that appears on the bottom-right of the Actions palette while you have your accordion element selected.
dieter
very strange - although freeway showed the action applied, it didn’t upload. after deleting all actions on my harddisk (on several places) and installing them again, it worked.
hm. freeways bevahiour with actions is indeed very confusing to me, sometimes the actions are shown all, in other documents only parts of them …
thanks again for pointing to the right direction!
dieter
