[Pro] scripty-accordion dos not work.
please, the freeway pro 5.6.4 seems hard way pro…
i tried 2 day now to create the script accordion . i installed the script (must be correct, because the actions menu show it) i follow the instructions MANY TIMES as they are in this website but in vain… there is not accordion.
does somebody kindly send me some help, the most SIMPLE ACCORDION, just 2 lines , which WORKS , so to see there is my mistake?
please help me.
thanks
If you can post a link to your example online we can look and see what the problem might be.
Did you look at the example posted on ActionsForge? ScriptyAccordion
There’s a link to download a working Freeway Pro file.
please help me.
thanks
i did not upload to a website yet, but i tried to preview in browser. the example you mention, it works in the internet, but when i downloaded this and i try to preview in all browsers shows the same : RESOURSE CANNOT BE FOUND, the following resources :
this is file eddy:users:waltz:Library:Application Support:Freeway 5 :Actions:General:scriptyAccordion,fwactionb:Contents:Resourses:Action prototype 1602packer.js for this recourse cannot be found, - it will not be published.
the same for scriptaculus181packer.js
SO IN MY BROWSER CANNOT WORK. I DID IT MANY TIMES.
PLEASE HELP
Make sure you download and install the latest version of ScriptyAccordion.
PLEASE HELP
From http://actionsforge.com/actions/view/110-scriptyaccordion
