Somehow, you have inserted an entire additional page inside your
existing page. That page includes links to MooTools, which is a
different JavaScript effects engine than ScriptyAccordion (and the
rest of Freeway) uses. MooTools “forked” off of the Prototype
JavaScript library many years ago, and the two libraries are not
compatible at all, because they use the same names for different
functions.
First of all, you can’t just put an entire page inside another page.
It’s not valid, and it’s guaranteed to confuse the browser. Some
browsers fall over and die when they encounter this sort of
construction. Safari is being forgiving, but Prototype.js (or jQuery,
or any other not MooTools JavaScript toolkit) isn’t so lucky. There’s
no good way to insulate one library from another, plus it’s just too
much JavaScript for anyone to have to download!
If you want to continue using this slideshow generator, what you need
to do is first use an FTP application to upload the entire collection
of generated files – HTML and images and scripts – into a sub-folder
on your server. Then, draw an instance of the iframe Action on your
page, large enough to contain the slideshow. In the Action interface
(while that drawn iframe is selected) you will see the controls to
turn off the border, etc, as well as the URL of the page you want to
show inside that area. If you made a folder named modern_wedding on
your server, and the generated slideshow page is called modern.html,
then you would enter modern_wedding/modern.html (manually) in the URL
field. Once you do that (and upload to your server) you will see that
everything just works. The reason that it does is that an iframe is
like a window cut through your Web page, through which you can look at
another site. It doesn’t matter at all what sort of scripting hijinks
you get up to inside that foreign page – it’s sandboxed away from the
rest of your site.
On Sep 13, 2011, at 12:29 PM, Lena wrote:
Well, I incorporated Scripty Accordion onto my website and its doing
its job for the most part. However, it has disabled my slideshows
(Which I created using Visualslideshow.com®). On one of the pages,
the menu shifted its position on the page. If Scripty Accordion is
not capable of working alongside VisualSlideshow®, I will just die.
(Ok, maybe that was just a little exaggerated). But really, I need
help with this.
My link is here: http://lenaosoriogemisic.com/index.html
Slideshows are found on the following pages:
WEDDINGS>Modern
WEDDINGS>Vintage
WEDDINGS>Romantic
Everywhere else (EVENT, GALLERY, ABOUT, CONTACT) the action script
works well.
