I’m using the great scripty accordion but for some reason the effect will not work when I rollover the headers (H2) only when the mouse is away from the text (to the right) then click it works?
There’s an element with the ID item3 sitting over the top of these
headers. It is stealing their clicks over the headers’ text, as it is
only 100px wide, but the headers themselves continue all the way
across the block of text (because they are block-level elements, and
fill to the width of their container, so you are able to click in the
clear area to the right.
The item3 contains your back to top anchor link. So if you cut that
from your page and then paste it as an inline element inside the text
box containing your bio (as the last element in that box) you should
get the behavior you designed.
On Sep 13, 2010, at 9:37 AM, Justin Easthall wrote:
Hi,
