carla
April 10, 2012, 12:08am
1
hey walter et al
I am working on a scripty accordian
works fine but I need help with 2 things
How can I omit the visible bullets? I unchecked in Inspector but then the action stops working
and
how can I have the link highlight colors. I also checked the Inspector and page links but nothing works
thanks for helping me
C
You probably have to create a style for your accordion div. Try this:
Make a new style.
Goes in Tag: #nameofyourdiv li
Name: should be empty/blank/nothing in it
Click on Extended
Value: none
See if that works.
carla
April 10, 2012, 4:14pm
3
thx Robin
this did not work
ah
I’m sorry, I had extra text in the Name field of Extended. Does it work if you just put in the Name field:
list-style-type
I had put :none after it, but I didn’t mean to, because none goes into the Value field.
carla
April 10, 2012, 8:42pm
5
Robin
nada not for me…
thx anyway
Can you post a link Carla?
One easy solution with no extra code/styles is NOT to use list items as trigger elements or show/hide elements
carla
April 10, 2012, 9:09pm
7
sure Dave
thx
here is example
what I am struggling with is eliminating bullets , having the orange highlight color ( orange) stay visible on current page and not having so much leading between items on menu.
I did lessen the leading on main list but the sub list items became too close
thanks for looking at it as always you have been such a great help to me…
http://www.carlagrande.com/menu2.html
Try this - first rename item1c2a (the menu container div) to menu1 (1st Tab in the inspector. Title:menu1)
Then alter the #menu1 style as below
#menu1 li {
font-family:'Quicksand', Helvetica;
font-size:12px;
list-type-style: none !important;
And see if that does the trick for your bullets.
carla
April 10, 2012, 9:45pm
9
Ok Dave
where do I insert this code?
You must have created this style yourself?
If so then you just edit it in the styles palette.
carla
April 10, 2012, 10:21pm
11
Yes made this myself but the code the way you have it with {
and the
do I just put this part in extended as Robin suggested?
carla
April 10, 2012, 10:26pm
12
sorry I must not understand what you are doing
Yes it is in the extended part but I have just noticed you have list-type-style
when it should be list-style-type
So in Extended the name should be ‘list-style-type’ and the value should be ‘none !important’ - don’t include the quote marks!
So you need to change that part and also change the name of your menu container to menu1
carla
April 10, 2012, 10:41pm
14
hmm i looked at extended and it is list-style-type and value is set at none
I will add your other code and get back to you
thx
carla
April 10, 2012, 10:44pm
15
Dave
I have done everything you said to do and nothing has changed
This what it looks like with my alts
carla
April 10, 2012, 10:50pm
17
I must be doing something wrong Dave I understand that but do not know what.
this is what I put in extended
list-style-type
none !important
Well I am still seeing this
#menu1 li {
font-size:12px;
list-type-style:
Copy and paste the following into Page>HTML Markup in the before end head section.
<style type="text/css">
#menu1 li {
font-size:12px;
list-style-type: none !important;
</style>
And let me know once it is uploaded.
carla
April 10, 2012, 11:02pm
20
Hi Dave
interesting we ar seeing 2 different codes
menu1 li { list-style-type: none:none }
I will keep trying
ugh
