carla
April 10, 2012, 11:08pm
21
Geez that was the magic trick Dave
it works now! did the markup code overwrite the style
You are a star
ok now I have to figure out the leading problem with main menu and the highlighting current page
I mean I love the CSS menu but it can not do what the scripty accordian does with multiple sub menus even the sub menu position action can only be to the right and left, not underneath
and there are things the CSS menu can do that scripty cannot… what a pain
Yes but this should be done through that #menu style - otherwise you will have to add that markup to each page (via the Master would be the best way)
Look through your styles palette and find the one that is #menu li and double/triple check what is in there!
carla
April 10, 2012, 11:23pm
23
ok
but I send you what I wrote in the style palette I have checked it several times
well thanks so much for your help Dave
Hi Dave interesting we ar seeing 2 different codes
menu1 li { list-style-type: none:none }
I see! - you are looking at the WRONG one - it is NOT .menu1 li (delete this)
The important one is #menu1 li
carla
April 10, 2012, 11:42pm
25
Dave
I have gone over so many times I deleted and made new
check it out
http://www.carlagrande.com/menu3.html
by the way I put #menu1 li in tag and for name I tried to leave empty like Robin suggested but it auto names it
so I made it menu1 I dont know
now the bullets are bigger
all the info in extended is correct. I must be daft
chuckamuck
(chuckamuck)
April 11, 2012, 12:00am
26
by the way I put #menu1 li in tag and for name I tried to leave empty like Robin suggested but it auto names it…
There should not be anything in the Name field. The trick to leave it empty is to Tab out of the field.
carla
April 11, 2012, 12:18am
27
check and Dave
ok I deleted old styles so no conflict and made new. thx for the tip on leaving name empty by tabbing
but alas there is no hope for me I suppose
it did not change anything and I have the correct info in the style palette
No you don’t!
You have to put the # in front or it wont work. Alt+3
This is what I am seeing - 2 styles
menu1 li { font-family:‘Quicksand’, Helvetica; font-size:12px; text-style-type:none !important }
The first has ‘text-style-type’ when it should be ‘list-style-type’
The second has name: list-style-type and value: none:none
It should be value: none
If you want to send me a page I will alter it and send it back.
carla
April 11, 2012, 12:48am
29
ok Dave
I said I was a bit daft
I know I have worn out your patience
I did put text-style-type
now i changed to list-
sorry about that… just had surgery yesterday not feeling too well
thanks all for your help
now on to the other problems I am having with this menu
thanks again Dave
OK - good but there is still one in there that is incorrect
#menu1 li { font-family:'Quicksand', Helvetica; font-size:12px; list-type-style: }
You should delete it.
carla
April 11, 2012, 2:41am
31
yes I deleted everything
in the Edit -Styles in main drop down menu of Freeway
for those who are as daft as I am
just check the duplicate boxes and go to minus sign to delete
Its the only way I could find it gone forever
