Hi, I am having issues with my Scripty Accordion as I need to include bullet points but when I preview it hides the body copy but not the bulleted text, is this actually possible
Not the way that you’re constructing it. What you need to do is insert an inline HTML box after each header, cut your paragraph and list items out and paste them inline within the box, so you have the following construction:
Header
html_box
Paragraph text etc.
* list
* list
Header
html_box
Etc.
Now, in the Action, change the show/hide element to DIV. that should do it.
Brilliant - thank you for that. Much better putting text in an inline box - especially if you have quite a few paragraphs.
One question though - I have styled text with names like ‘Header’ and ‘Text’. With the accordian action does all the styles have to fit with the ‘h1’, h2’ etc?
The headers don’t have to be headers per se, they just have to be different tags than the body text. You’re already taking care of that with the inline div, so your header could be a P tag, or an image, or a header (h1,2,3…).
