OK. I abandoned the free Lightbox action because that wasn’t working properly. I couldn’t get it to read a folder, I couldn’t get it to do more than one pic on a page, etc.
So…I switched to Scripty Accordion and I can’t get THAT to work on more than one image on a page.
I plan on having a bunch of pics on a page all in separate boxes. After I do the second one, the first box has this spinning wheel that just keeps rotating. If I add another, then I have two boxes with spinning wheels.
Any idea what’s going on? I’ve gotten both of these to work before, now neither do.
Try putting all of the images that you want to work together in a
parent HTML box. Remove the Action from each image, and apply it to
the HTML box (once). The Action will propagate to all of the
thumbnails within that box, as long as each one is linked to a
separate full-size image.
The easiest way to do this is to draw an HTML box over all your
images, send it to back, then cut each image one at a time to the
clipboard, double-click into the HTML box so you see a flashing text
cursor and paste. Click on the pasteboard to get back to the next
image, and repeat until you are done. Then set margin on each image to
keep it from crashing into its neighbors.
now neither do.
