[Pro] Scripty Fader in Chrome
I am so delighted with the Scripty Fader action but having tested it in a few browsers, it doesn’t seem to work in Google Chrome but works great in Safari and Firefox.
Does anyone know what I can do to ensure it works in Chrome as I really want to use it?
Many thanks
Lindsey
Could you post a link to a page that shows it failing there?
Many thanks
Lindsey
Walter,
Thank you for quick response - I’ve just taken a look at one that I’ve previously uploaded and it is working fine. I then checked it on preview in browser in Freeway and selected Chrome and it didn’t work - so the issue doesn’t seem to be that it doesn’t work, just that it doesn’t work in a local preview in Chrome - I can cope with that. I think I just panicked that I wouldn’t be able to use such a great action!
Many thanks again, Lindsey
If you’re seeing it not work sometimes and working others, try holding
down the Control key and choose Publish Everything from the main menu.
I’m noticing a trend here with the Scripty Actions and certain
versions of Freeway. Nothing I can pin down just yet, but the
SuperPublishEverything trick is a useful work-around when things don’t
work correctly all the time. (It’s a very big hammer to use on a large
site, especially if you have massive video uploads, but sometimes it
is what you need to shake Freeway awake when it comes to Action-
supplied files.)
On Apr 25, 2011, at 5:30 PM, Lindsey wrote:
Walter,
great action!
