[Pro] Scripty fader
Was working fine now I get weird text replacing the actual text? 404 (PAGE NOT FOUND) ERROR?? Instead of my text?
http://www.ayearofkindness.com/365/index.html
No clue!
Help??
Are you using Freeway to upload your site? If so, hold down the
Control key and choose the hidden option Publish Everything… from
the File menu. Once this process has finished, choose File / Upload.
If that doesn’t clear the problem, then try removing the Action,
publishing once (locally) and then re-apply the Action and publish
again.
No clue!
Help??
K - tired all the above - even uploaded it without the scriptyfade - was fine, added back the scriptyfade uploaded back to same error?
Oh and yes using Freeway to upload
You should be seeing files named _home.html, _item2.html, _item3.html
and _item4.html in the same folder as the home page. According to your
home page’s source code, those are the elements in the home group.
Could you please publish your site once with the Action removed, and
the data source box visible in the middle of the page? I’d like to
look at the source code of that element, as it’s not clear to me where
this is going wrong.
Ive removed the actions and left the _home (data?) window in place
Thanks Walter appreciating the help…
I see the data, and it looks perfectly ordinary.
So then you apply the ScriptyFader Action to the home box, The
ScriptyFader Option Action to each of the additional boxes, and the
ScriptyFader Thumbnail to each of your dots; and you use the picker(s)
in these Actions to wire everything up, right?
When you publish, do you see any errors in Freeway?
Could you try deleting the entire content of your local Site Folder
(the one that Freeway publishes into on your hard disk), or simply
target a new Site Folder using the Document Setup dialog? You need a
fresh start here, but removing the Action, publishing, and then re-
applying the Action should have done the job.
Yes I did and error still persists?
K will try the above now
No errors when I upload -
Its uploading now from a new folder
GREAT - That seemed to have done the trick??
Any ideas what that was about? (for future ref)
Thanks!
No, just that Actions which create files (like this one) can get hung
up from time to time, and I don’t know precisely why. The application
thinks it’s made the file, but it hasn’t. Or the application thinks
it’s updated the file, but it hasn’t. Creating a new site folder is
kind of a large hammer to hit it with, but sometimes that’s what it
takes.
Thanks!
Ok -
Thanks for sorting -
