I have a problem with scripty lightbox. The lightbox will work when i preview it or preview in browser but when i upload my site to the server it will not work. Any ideas?
And is that exactly the same on the server? You can’t add folders to
the Resources folder on your computer and expect anything to change on
your server.
In fact, it’s a very very good idea to leave the contents of the
entire Site folder completely alone. Freeway manages that for you, and
doesn’t take kindly to people tidying-up behind its back.
Freeway doesn’t do an FTP “mirror” of the Resources folder (or the
Site folder) to your server, rather it tracks everything that it
changed, and only uploads the things it knows about. This is one of
the reasons why you can split a Freeway site into multiple documents,
and each one will work independently of the others. Each document only
uploads the things it knows that it made or changed.
On Mar 29, 2011, at 4:24 PM, Steve wrote:
yes the images are in a folder within the resources folder
Do you mean that you put them there?
If so then that is a HUGE NO! NO!
The Site folder is FW’s domain - dont mess with it on pain of death and destruction. Or at least unless you know what you are doing.
FW will not upload a file you put in there - it will only upload stuff IT puts in there.
Any media like that should be stored within the FW created Media folder.
Instead use an action to get the file to the server. If you use the Graphic Link to File action on the image that you want to be the lightbox link then FW will upload the image for you.
The reason the lightbox is not working is because the file hasn’t been uploaded to the server.
