sorry no link as took those bits offline
Imac, os x.10.9,
upgraded to v 0.8.2 of scriptyaccordian
installed ok in actions, took it out and re installed to make sure
lost the smooth accordion action - has become ‘jumpy’
also following message comes up when trying to view designs with a browser (safari)
I’m on pro v 6.1.2
but some was written in 5 and 5.5 - is this the problem ?
guidance for lost is welcome !
Publish Problems
18 November 2013 17:23:38 GMT
RESOURCE CANNOT BE FOUND. The following resources cannot be found and will not be published.
The file Macintosh HD:Users:rgiddings:Library:Application Support:Freeway 5:Actions:General:ScriptyAccordion.fwactionb:Contents:Resources:Actions:Support Files~:prototype1610packer.js for this resource cannot be found.
The file Macintosh HD:Users:rgiddings:Library:Application Support:Freeway 5:Actions:General:ScriptyAccordion.fwactionb:Contents:Resources:Actions:Support Files~:scriptaculous183packer.js for this resource cannot be found.
It sounds as though you don’t have the Action installed correctly in Freeway 6. The Action can be cached in the document, but it rarely works correctly if it isn’t also installed in your copy of Freeway. Look in your Library folder (hold down the Option key and choose Library from the Go menu in Finder). In there, follow this path: Application Support / Freeway Pro / Actions / General. If you don’t see the Scripty Actions there, then drag them in from the Finder. If you do, check each one to be sure it’s the version you expect.
I haven’t updated ScriptyAccordion for 6 yet, but it should work. For more compatibility with newer versions of Internet Explorer, also apply the Protaculous 2 Action to the same page, and check “Enable Scriptaculous libraries” in the interface. You don’t need to do anything else, just having it on the same page will fix the references of prototype.js and scriptaculous.js to be the latest versions.
Imac, os x.10.9,
I’m on pro v 6.1.2
Publish Problems
hi thanks
0.8.2 installed ok as far as i can tell
then i took off scriptyaccordian actions of every page in the file, published or not
this then stopped the publish problems message
then added scrityaccordian to one page and tried it on safari
no error message but was exceedingly jumpy and random - but sort of worked
after supper will try upgrading Protaculous 2 Action and trying that
