Hello,
On the same page I use:
ScriptyAccordion and Exhibeo: “Slide” and “Showtime”.
As soon as I add a second “Showtime” (tried different files), SA stops working, removing the “Showtime” won’t fix the problem. No problem when I add a second “Slide”.
Any suggestions?
Thanks, Lode
Exhibeo mailing list
A link to the page online would help.
http://users.telenet.be/loderosel/home-2.html
Here you go. Noticed that “SmoothScroll” stopped working also.
SA is on the first page under the puppies: “Fotowedstrijd: Win een FOTOSHOOT!” and “Ehbo Avond”
Thanks, Lode
