Someone could explain how to use the action ScriptyAccordion?
I’m Italian and it may be that the translator makes me some joke, because the instructions that I found I did not lead to anything.
Thanks in advance.
1 - Draw an HMTL box on the page where the effect should go.
2 - Double-click inside it and type the first header text.
3 - Press return, then type the first paragraph to show, and press return at the end of it.
4 - Style the header by quadruple-clicking on it (to select the entire line plus the return at the end) and clicking the h2 option in the Styles palette.
5 - Select all, copy and paste a bunch of times to create a set of options
6 - Click elsewhere, then click once on the HTML box and apply the ScriptyAccordion Action to that box. Adjust the settings to open on click, and to have the first option open at page load.
7 - Preview in a browser, click on any header, the others close and the new one opens.
If you are still having trouble then post a link to your example online.
