Hi All,
Does anyone know a way to have the ScriptyFader action cycle through only once. Basically I'd like to fade between 2 images but have it happen only once and not fade back to the original image.
I know show/hide target layer with a target group timer or sequence timer can do this, but the problem is I can only have one of those on a page. I am going to have several separate sets of fading images which is why I thought the ScriptyFader would be a better way to go.
Actually, I'll tell you the full thing I'm doing so maybe there is an even better option. What I'm trying to do is have a photo that is B&W, it will then fade to Color, and using Carousel slide to a new B&W photo. Then that one will fade to color and so forth for a total of about 4 or 5 images.
The carousel will continue to run after all the images have changed, but I don't them fading back to the B&W image.
Any better suggestions than using a Carousel/ScriptyFader?
Thanks.
