[Pro] scriptylightbox & link to smugmug not working
Is there a reason why a text link/html wouldnt work when linking to a ____.smugmug.com site? When I preview in FWP (in Firefox) it opens a whole new link, not within the lightbox. Is there something I am doing wrong?
Works for me.
Do you have the action applied to the html text container?
Tried it with http://cmac.smugmug.com/
Spoke too soon - it starts out in the lightbox window and then breaks out of it.
Must be some ‘breakout code’ on these pages.
Walter!
Yes, I have it applied to the html text container. The scriptylightbox loads… then the ‘border’ of the lightbox disappears and the whole smugmug page appears as a normal full page. I am previewing in Firefox and Safair - the lightbox disappears altogether. So, with that gone, there is no option to “close” that lightbox to remain on my site.
Sigh - great. I guess I have to figure out how to get a custom banner at the top of the smugmug page so it can be the same navigation as my FWP page navigation. Not a clue how to, but… unless this breakout code can be broken…
if you are using waltd’s scriptylightbox action then have you applied the external page load tags as described in the thread for the action elsewhere ?
I can’t give you the link but a quick search will show it up.
It may make no difference but I had all sorts of trouble using handcoded lightboxes and needed to use the page-external option which we the discussed on the other thread…
mm
