Im working on a history page and having trouble getting scroll layer to work. Here is a link to the page… click on “Act 1”. (I noticed when I do this that the URL changes and there is a # symbol after the .html. Why is this?) Anyway, here’s the link:
I could include the freeway file too but not sure how.
I have the scroll content off to the side of the page and the scroll layer is partially hidden by two transparent png files. The act 1 button is a rollover that triggers a show/hide layer which is the original curtain image. (act II and III arent active yet)
Any thoughts/ suggestions would be greatly appreciated!
Quick non-technical observation - are you scroll arrows hidden below the active (Act 1) scroll area? Or did you draw them within the scroll box, in which case they may be children of that box. Check you Site Panel and drag them out if necessary, bringing them to the front.
(I think the # symbol relates to the scroll layer being targeted - I get the same on my sites that use a scroll layer and it doesn’t stop anything from working).
HTH Colin
