[Pro] Scroll Layer issue
Hi all,
I’m trying the scroll layer action suite for the first time and have a few issues. The small flowers by the central window are the scroll buttons but the mouse behaviour that sets the scroll seems to happen way off of them and using the buttons has inconsistent results.
Many thanks
nige
http://nlgdesign.co.uk/lovelytaboos/index.html
I don’t know how to fix the scroll layer thing, but I can tell you that it
is maddening as hell. I’d prefer a single long page to that.
On Sat, Jul 7, 2012 at 6:50 PM, Nigel Gilbert email@hiddenwrote:
Hi all,
Many thanks
nige
You appear to have the scroll attached to div id=“Skyback”
Hi
Well spotted :slight_smile:
However I still couldn’t get it to work. Is there a way to kill the bottom horizontal scroll and just have the vertical when the html object is set to ‘auto’.
Nige.
Just not sure why you think you need it on this page?
I would remove the Bold from your text and with that the scroll only reveals an extra 3 lines on my Mac.
Just move the pic up a little and with it the text, then no scroll required!
