carla
January 10, 2011, 11:37pm
#1
hey all… I wonder if anyone can help me with this nutty problem. Scrolling layer. I made a few for a website and text inside is perfect, no glitches, but I have this one I am trying to align in the center but it is off by a lot. I have tried many things from creating new action, new page clean and removing styles to clear and redo. Nothing works…
It is only one though, that is acting up, the other scrolling layers are fine. Any solution to this??
Thx
A page we can look at?
carla
January 11, 2011, 12:14am
#3
Dave! My hero from Glasgow!
Happy New Year to you
Here is link to page
http://carlagrande.com/collections
Am I correct that you are trying to centre align the text?
All these have lines of text have style184 applied to them text-align: right;
carla
January 11, 2011, 12:57am
#5
Dve
yes I am trying to align text in center, ok look again I have it centered and it is not working.
Reduce the width of the box and make sure that there is no padding on it - either on the box on the page or the scroll layer.
Match the widths of the two boxes
carla
January 11, 2011, 1:48am
#9
jeez Dave
I will try again with both layer & content boxes same size. that is why? strange I have same set up on other pages and it works perfectly
C
carla
January 11, 2011, 1:55am
#10
Dave
not working for me at all. I can not for the life of me figure it out… as i said my other scrolls on same website work fine
there is no padding. I made new boxes , same size
nada
They don’t have to be exactly the same size - as long as the ‘receiving’ box isn’t a lot bigger than the layer box.
At least that worked for me. I was also starting with virgin text. Copied from your site and ‘washed’ in BBEdit
carla
January 11, 2011, 2:03am
#12
What is BB edit
I should do that too . I am sure that it must be corrupt and that could be the reason… I will do the same if you lead me in the right direction
carla
January 11, 2011, 2:04am
#13
ok is it Bare Bones edit. I am downloading demo now willl try it thx
BBEdit is a text editor but you could use TextEdit instead. Just make sure that you set the Preferences for a new document to be plain text.
Open TextEdit and make a new document. Copy and paste all the collection names from FW and paste into TE
Select all in the FW box and apply no style or Style>Remove Styling
Paste back in your text from TE and apply only the centre align and size (14px) for just now.
Make sure boxes are wide enough to hold a complete line of your text (as wide as the longest) and make sure they are pretty near the same width with no padding on either box.
Try it
carla
January 11, 2011, 2:19am
#15
Dave
I followed instruction used Text edit
and put back in same thing
carla
January 11, 2011, 2:27am
#16
Dave
so I redid entire scroll and used clean text and same problem. I must be jinxed
I do not bother changing font
Your Div id ‘collectionlist’ to me is not showing to be as wide as the container Div id ‘scroll’
As a result the inner ‘collectionlist’ sits at the left of the wider ‘scroll’
So text centered in ‘collectionlist’ is offset to the left
Do you want to send me the FW file for that page - usual address.
carla
January 11, 2011, 3:21pm
#18
Hi Dave
thanks
that is strange because dimensions on container is 675px wide/152px and content box is 650px wide x
so it is almost as wide
file is in same place I re uploaded new page
carla
January 11, 2011, 3:26pm
#19
Dave
now I reset width to layer 675px and content 670 px
nothing changed.
Here is one I did that works perfectly
I uploaded another page that works perfectly here
http://carlagrande.com/groupexhibitions
I even copied that page to insert clean text. I am cursed
carla
January 11, 2011, 8:53pm
#20
Ok Dave
so I have been trying to figure this thing out and I have now done that. If the boxes are both much bigger than the widest line of text, it throws off the whole scroll
That is it! all that drama with the simplistic answer
thx for your input
C
