Hi Carla
So for the sake of others that might come across this thread what was the problem with the layout and what sorted it?
Hi Carla
Hi Dave
yes as I said above the content box must be the approx. width of the length or width of the text. period. That was the problem all along…
Other scrolls I made had several lines of text longer than others but they could hold a wider content box. is this understandable?
Thanks for your help Dave. Your width on your example, although narrower than my new corrected one worked fine too. I just had to keep thinking about it. and then I tried and it worked
let me know if I need to explain more
thx
let me know if I need to explain more thx
Not for me - I was just looking for the clarification that should always end a thread so that those who come after can see the solution down at the end.
Glad to help.
Dave
I know this was for those who run into the same problem since you are my teacher… I asked you if I was clear for whoever may read this! ha!
thanks again as always and I enjoy learning and figuring things out.My websites have given me a great deal of pleasure
thanks teach
C
