Or even easier, just draw an HTML box the size you want the menu to
appear, paste the much-too-long content into it, and the in the
Inspector, change the Overflow setting from Visible to Auto. The
browser will draw and manage a scrollbar for you.
On Mar 23, 2011, at 11:47 AM, chuckamuck wrote:
This example from Walt should get you started at least in the right
direction.
The iDevices don’t render scroll bars. If you know the trick (drag
with two fingers) you can scroll the content inside the scrolling
area. But that’s asking a bit of your visitors. You might want to find
a conditional stylesheet or JavaScript shim to remove the overflow
setting on this box for those browsers. In an ideal (fully inline)
layout, you could simply remove the height property from the scrolling
div area, which would cause it to expand to suit its content. This
would horse the rest of your layout around, so you may not like that.
On Mar 23, 2011, at 5:09 PM, Gray Owl wrote:
Hi Walter
I took the easier option but when viewed on my iPad you don’t see
the scrollbar at all
