mog
(mog)
November 15, 2011, 1:08pm
#1
Hi,
I’ve just added Webticker to enable a scrolling text box which works perfectly but I notice if I try to add another scrolling box with Webticker on the same page the second one is frozen. Is there a way to enable two scrolling text boxes? Also Webticker only allows horizontal scrolling. Does anybody know of another action that would enable the text to scroll vertically (and without disabling the other action.)
Thanks for your help
Mog
This doesn’t use an action - instead it uses a script on the server that allows online updating.
http://www.deltadzine.net/test/scrollerpage.html
If it is of interest I can point you in the right direction.
mog
(mog)
November 22, 2011, 10:23am
#3
Hi David,
Thanks I’d like to try this option if there isn’t an alternative action for this.
Mog
Here is another example with a link to the site where it is available. http://www.deltadesign.co/fw_examples/autoscroll.html
This is a link to the source for the first example’s script. Page Not Found - UPOINT Impermanent Loss Calculators
mog
(mog)
November 24, 2011, 10:21am
#5
Hi David,
That’s great thanks I’ll look into these.
Mog
